1 - 20 of 32 Posts
this is my project its a 4bt nv4500 np 205 and dana 60 gm 14 bolt jeep it had a chevy 350 in it before this 4bt this is about round three it had all kinds of tranies and tranfercases and axles in it but i think i got it right this time.
Discussion Starter #2
heres a couple more
heres my cross member just got some odds and ends to finish up. not sure if i need the extra mount on the np205.
What bellhousing are you using
Looks really good, that thing is gunna be a beast!
thats pretty sweet!!! a P pumped 4BT wit ha NV4500 and a 205!!!! and a newer style"with ribs" 14 BOLT the transmission and crosmember seem a lil low to me is it gonna be a heavy off roader? could have the engine went up a lil more? body lift maybe? just a thought otherwise nice work looks good
Discussion Starter #8
the bellhousing is an advanced adaptor kit for a gm nv4500 to sbc. ill get the part number if needed.
Discussion Starter #9
looks like a great project.
here is a link to some pics of mine.
http://www.nrvjeepclub.com/phpBB2/viewtopic.php?t=728
Its a 87 yj with a 4bt out of a step van with a 700R4 231C combo out of a blazer. I had a custom torque converter built and everything else pretty much fell into place. I didn't even have to have my drive shatfts altered. yet.
nice jeep its nice to see another cummins jeep is it running yet
Discussion Starter #10
the reason the cross member is so low is my driveshaft angle is so much or was it is 20 degrees now thats where i like it the shaft is 1410 series joints and they say it can run a 35 degrees but last summer it was at 30 degrees and the center barring wore out and broke as i was towing my boat not fun so this time around i set it low (engine trany transcase) to keep the drive shaft straighter and i elongated the wheelbase. its still got two feet ground cleance and it keeps the center of gravity low its got 1 1/2 springs and a spring over so its about 7 1/2 inch lift total.
Steve to answer your question on the added T-case support, yes you will need it. GM, Ford and Dodge all used an extra support on the married 205 t-cases. It is just too heavy for the tail housing to support alone.
On that last picture of your rear drive shaft, is it just me or is your pinion angle way out of alignment. It looks in the picture like it is pointing higher than the t-case.
Discussion Starter #12
ill have to add something for the extra support. and good eye the angle is out the pearches where welded on from my old setup with the chevy 350 i dont want to cut the pearches off and reweld them so im going to add some shims maybe 2*-4* should do it steal of course with the pin that goes through them and the leaf pack i didnt want to address them until the cross member and the rear axle (streched) and the weight of the tub were finished
Discussion Starter #13
ill show all the pics for the rear axle strech and trailer hitch and also a rear mounted 12000 pound winch next weekend
Discussion Starter #14
new cummins
my project got delayed this weekend. for a worthy reason i got a new truck just could not wait any more its a 2004 quad cab cummins HO color blk 45k on it IM SO EXICITED this truck pulls like nothing i had ever driven i think i might put my new 12000 pound winch on the front of this truck i just cant let it side track my jeep some pics tomarrow i noticed the 04 looked like they had bigger axles and a 4inch exhaust compared to the 03
Discussion Starter #15
some pics of the frame extension and trailer hitch i decided to skip the 1200 pound winch to much work.
Discussion Starter #16
more
Discussion Starter #17 (Edited)
more pics
Discussion Starter #18 (Edited)
heres some picks before i started the 4bt it had a 350
Discussion Starter #19 (Edited)
heres some chick i met on the trail lol
Discussion Starter #20
jeep
i got my jeep on the road after a year. i ran my gears and tires and i think it was like 1800 rpms at 60mph but just driving normal 1st gear is the usual low gear quick understandable 5.56 but second is almost not worth useing and 3rd feels like its reving to much i shift into 4th and it bogs down until i get to the end of the gear and shift into 5th and again bogs down until the end of the gear i have a nv4500 and a np205 and 4.10 gears with 37inch tires they have worn a little. maybe i got the wrong gears i dont know i dont want to loses my crawl ratio but i need it to be drivable i may not be taching it out enough because it sounds so loud. any input would help maybe someone has this setup
1 - 20 of 32 Posts
