Well it's finally happening. I've wanted a 5 speed swap almost as long as I've had the truck, I never was a big fan of the ttb, and when I discovered the 4bt I decided I had to have one. Finding all of this locally for a decent price was difficult, but I think I made out alright. Subject of the swap is my first vehicle, a basically all stock 95 Bronco with a tired 5.0 e4od in need of a rustoration.
Heart of the transplant, a 4bt with 1,200 hours from what I believe was a Pettibone C8000 Telehandler, picked the motor up for $2000. Heres a little test run after figuring out the starter and fuel shutoff solenoid were 24 volt. That had me scratching my head for a bit.
Adapter, starter spacer & flywheel from a ford 4bt was pricey, but cheaper then any online options and considering the decent price I think I got for the engine I ate it. Drove for these for $1000. A week later another set shows up in my town for $600. 🤦♂️ Oh well, the parts hunt continued.
Couldn't decide on the tranny, so FB market decided for me with a zf5 s5-47 from a 5.8 f250, picked it up the day it was listed. Trans, tcase, front driveshaft, & pedals for $600. Came with clutch and line but I will be putting new ones in.
I was planning on rebuilding the ttb and holding out for one tons, but plans change, I wound up with a high pinion dana 44 from a 79 f150, everything there except the calipers for $400, I believe it has 3.50 gears, that'll have to change to match the 4.10 rear. 4" front springs & rear blocks until I get new leafs or do a shackle flip, undecided between 33s or 35s, leaning towards 35s. Brake upgrades will be tbird calipers, f350 wheel cylinders, 1 ton master & booster.
With most parts in hand I started changing some things around on the engine, flat intake plate & 12 valve intake heater with a straight intake horn, 90° reducer intake elbow, exhaust for a charge pipe, center dump manifold with the turbo up top, modified drain tube, block heater, mustang alternator with 8 rib pulley on a cummins ford alternator bracket & lower mount I made, 7.3 idi starter, 12 valve vacuum & power steering pump combo with a support brace I made, my take on the killer dowel pin fix, (the pin was working its way out, scary!!) I had to take off the oil fill on the side of the block and I made a plate and used some gasket maker to block it off, oil fill in the front valve cover now. Probably could've got a freeze plug for it instead. I changed all the normal gaskets and seals while it was out, hopefully it barely leaks like it was, i couldn't believe how clean it actually was.
Originally, I was hoping to find the ford breadvan mounts and use the 80-86 inline 6 f150 motor mount plates but I couldn't find the breadvan mounts, not many of them left. There isn't many aftermarket options and the few are very expensive, I decided on going with a set of obs ford diesel motor mount plates and making the brackets for the engine. One day I was perusing ebay listings and actually found a set of the 45° ford 4bt motor mount brackets for $150. Worth the price in my opinion, saves me the hassle of stabbing the 800 something pound engine in and out to make mounts. Then I found a set of the 80-86 inline 6 engine perches. I plan to use the drivers side inline 6 perch with the passenger side diesel perch, I saw this done by someone else once and wanted to try it since I have both sets.
