1 - 3 of 3 Posts
Can anybody tell me where the a/c diode is located. I went to a shop the other day and they said under dash driver side. No help. By the way it’s an 04 excursion. I think I burned it out by hooking the compressor up backwards but I can’t find it to test
Discussion Starter #2
Someone suggested I just put in a switch and relay wired to the pressure switches but I want to keep the dash switch working, so if I knew which relay goes to the a/c , I could just tap in there. Problem is, I can’t find a diagram showing which relay is for the a/c. Somebody has got to know where the relay or diode is at. HELP PLEASE
1 - 3 of 3 Posts
