it may be stuck if you cant jiggle it free you will have to get crafty with a scribe or wire or somethingpull the throttle sometimes the pin is riding on the afc just jiggle it a little.
Pictures please???No dice.....that sucker IS NOT coming out no matter what!
Yeah, I already have it pulled up. it doesn't help either.....just says: "Above, the diaphragm has been lifted out and removed"...but doesn't give any tips on getting it out.Better AFC removal photos and 3200rpm spring How-To,
http://dens-site.net/Dodge_CTD/Governor_Spring/
The eccentric cone slid up and down fine but would not come out, so I couldn't tell where it was "clocked" at. The small horizontal pin, about 5/32" diameter, was frozen solid. I cleaned everything up and oiled the pin, and also oiled the eccentric slide bore. Everything seemed to be working fine.Good to hear! Was it the eccentric cone or the pin that rides on it that was seized?
