1 - 3 of 3 Posts
i want a bolt-on air compressor for my 4BTA
i've seen ones that bolt near or in place of the PS pump with PS pump behind it.
I need a SMALL compressor.
nothing fancy
just enough to keep air tank full for occasional use.
and no thanks-I do NOT want an electric pump...
need info on brand and model number if known.
Thanks!
I chose a York A/C compressor as a standalone option, running off of a v-belt with a pulley mounted on the front if the crank.
The York's are still to be found in the boneyard and they adapt easily to moving air, I added a 7 gallon tank between the frame rails and I can easily fill 33's even at higher altitude or run one air tool if needed.
Vendor
In my "misc pix" album in profile I have pics of Cummins/Wabco comp I had for sale. Single cyl.
1 - 3 of 3 Posts
