1 - 5 of 5 Posts
Looking to see if anyone has any suggestions on a good part number that will direct fit minus the vacuum pump into a 4BD1T.
Would like to upgrade mine to something 100A or higher, and have no need of the vacuum pump in the back of the original.
Anyone figured out which one would fit directly into same spot and same mount area without much modification, other than unbolt/bolt?
I'm hoping to find a direct fit part number that uses same mounting (not worried about the power outputs)
Just want the same setup as far as double pulley Vbelt and same mounting, yet higher AMP output if possible.
Don't get concerned about pulleys as all major brands can swap pulleys between about a dozen different options.Main thing is mounting tabs, volts and amps are what you need.
I've got an OEX alternator which is a copy of a Hitachi. But it has vacuum pump.
OEX HXA00570 Amp 12VCopy of Hitachi SP105469
The replacement part often comes without an air pump (they expect you to reuse yours)
I assume you’re going Hydroboost brakes off the powersteering?
1 - 5 of 5 Posts
