41 - 60 of 107 Posts
· Premium Member
Discussion Starter · #41 ·
Alternator bracket done. Placement, CAD, bracket and finished product.
Knowing how hard it was for me to do those four simple steps, really puts in perspective how cool stuff fellow members are doing and how easy they make it look.
Automotive tire Motor vehicle Automotive wheel system Gas Machine
Machine tool Gas Bumper Automotive exterior Auto part
Automotive tire Motor vehicle Gas Automotive wheel system Automotive exterior
Automotive tire Circuit component Motor vehicle Engineering Gas
· Premium Member
Discussion Starter · #42 ·
· Premium Member
Discussion Starter · #43 ·
Intercooler in core support. Shoulda, woulda, coulda gone bigger. Just saving cents, still rated above the ballpark 800cfm my setup will require.
Grille Motor vehicle Automotive design Automotive exterior Hood
Core support in truck with original 6.2 rad and shroud, I’m happy so far.
Vehicle Car Hood Motor vehicle Automotive design
· Premium Member
Discussion Starter · #44 ·
Is there a minimum PS fluid reservoir volume that has been found to work?
Bought this, not sure if it’s too small. Advertised to hold approx 1L, just over a qt.
Motor vehicle Automotive tire Automotive design Automotive exterior Automotive fuel system
Not final placement, just mocking it up.
· Super Moderator
Looks good, for your turbo caps I used blanking plugs but left the rubber seals out so they wouldn't burn/melt. Intercooler is big enough, the CFM ratings for those are all BS anyway. Really good job making the original shroud line up.
PS volume looks fine too.
· Premium Member
Discussion Starter · #49 · (Edited)
Funny you should ask that, today I came to work early to solve that piece of the puzzle.
So, PO was running an Hx30w turbo. When he sold me the motor he was kind enough to leave the flexible metal pipe he was using as a drain.
Automotive tire Motor vehicle Hood Automotive exterior Gas
Unfortunately for me, the Holset flange bolt pattern is slightly different from the Volvo. I chose to drill and tap for a 3/8 bolt to fill in the holes and then redrill for my application. Bolt stubs are held in with red locktite.
Gas Fixture Auto part Composite material Metal
Automotive tire Motor vehicle Bumper Gas Automotive exterior
Just for giggles, oil drain flanges, close but don’t match. Left to right, Holset, Volvo, 4bd2t OEM
Snake Wood Scaled reptile Audio equipment Serpent
Drain line to block.
White Light Black Motor vehicle Automotive tire
· Premium Member
Discussion Starter · #52 ·
A couple of pics sharing some progress.
Motor vehicle Vehicle Automotive air manifold Gas Auto part
Changed from the larger 6.2 rad and shroud to smaller 350 version, helped packaging the intercooler pipes. Spent some time looking for proper rad hoses and avoid using the one that shows I have stock in a hose clamp factory.
Second attempt at a suitable air filter housing, junkyard nearest to me has mostly Fords, so that what I’m using.
Motor vehicle Vehicle Hood Car Automotive exterior
Oil pressure and coolant sensors are in, would like to still have dummy lights on dash so working on that now. But I’m running out of excuses to try and fire her off…
Good day to all.
· Premium Member
Discussion Starter · #54 ·
You'll gain boost response with a bigger intake pipe. Basically a bigger pipe acts as a reservoir so it can pull more air in a surge without having to accelerate airflow along the entire pipe. See if you can match diameter with that air-filter outlet.
Understood and I’ll make that happen.
May I ask what your opinion is of what I have set up on the other side of the air filter intake?
It’s an ARB snorkel for 80 series Land Cruiser, modified to fit my needs. Put there to provide fresh air to the motor, no intention of deep water fording or mudding. If the snorkel isn’t more of restriction than benefit, I’d eventually like to swap out the scoop for a Donaldson pre filter top.
Plant Vehicle Car Hood Automotive tire
And Mr. Dougal, thank you for being so generous with your time and knowledge to this and other forums. Turbo choice and installation, thread pitch for water inlet and oil sensor, are a few items that you’ve inadvertently helped me with during this particular project by reading past threads. That’s not counting help with the other rebuild as well.
If you ever come over this way, I’d like to buy you food and drink in a non romantic fashion.(y)
· Premium Member
Discussion Starter · #59 ·
And the original goal this weekend, use what I had to make an exhaust system. The section closest to the firewall got wrapped in exhaust heat shielding tape.
Hand tool Wood Tool Gas Metalworking hand tool
Hangs a little low in the back, but it will work for initial test drives I think.
Wheel Tire Automotive tire Automotive lighting Hood
· Super Moderator
Compressor plumbing corrected, thanks again Mitchb. (y)
Dougal, stepped up intake pipe to 3”. Can’t go larger due to clearance issues. I will remember what you said and look into oval pipe when the piggy bank recovers.
3" will work well and that looks good. Oval pipe can be made with a round pipe and a hammer, vice or press. 4" round could be flattened to about 3" height and almost 5" wide.
