Thank you for taking the time to answer and taking advantage of your attention, a few more questions.
In your opinion is that too much? Do you think I should work on trying to lower that amount of vacuum? Would it be worth it to put the informer pre filter see to see if I should upsize air intake pipe? And if that is decent try a different filter?
Edit: the only reference online I’ve found is from Donaldson for their filter minder and they have that amount of vacuum when the filter has seen approx 85k miles, lol. Not new.
Filter Minder® - Typical Air Filter Restriction Readings
