Does your 4B have a Load Governor Injection pump ( industrial) and you need a Automotive application (speed Governor)
I am going to build up a 30KW Genset. I have a automotive Bosch VE Pump and need a Industrial Load Governor Pump, such as the following;
Prefer--- a Bosch Distributor Fuel Injection, VE Series with Variable Speed Governor
for 4B series engines
Also considered are;
Stanadyne DB4 Distributer Type FI Pump for 4B Series (Load Governor)
Lucas CAV-DPA Distributer Type FI Pump for 4B Series ( Load Governor)
If your interested I have;
Cummins Re Con Bosch VE Pump, Automotive Application (Speed Governor)
the numbers on the VE Pump are;
3908191 RX
M112396012
Phase II
This pump is a Recon, but NOT a new Recon. It does have in service time on her. It was on a engine that was taken out of service due to a crank thrust bearing problem. I was told the engine ran, but I have NOT run it. I do NOT know the condition of this VE Pump.
Paul
3908191 RX
M112396012
Phase II
Paul
