I currently have a problem with my engine not starting that only occurs about 25% of the time. I can hear the solenoid on the starter clicking, but it does not fire up. I have swapped out the starter, battery, battery cables, ignition switch and so far no luck. It is freaking frustrating in that it doesn't always happen. Sometimes, when it's not starting, I keep turning the switch on and off and it will eventually turn. Other times, I just let it sit for a bit and it fires right up.
Here's my setup:
-4BTA (CPL 858)
-Dual Walmart Yellow Max batteries (I know, but they have gotten good reviews)
-12voltguy.com dual battery setup
-rebuilt starter (I also have a new one)
-new ignition switch
I have gotten the batteries tested and they are fine. What else should I look for? Could it be a bad alternator not charging the batteries deep enough?
Should I go up to a Oddyssey battery with tons of CCA? Any help is much appreciated.
-DG
Here's my setup:
-4BTA (CPL 858)
-DG
