1 - 7 of 7 Posts
If the B3.3 has the rear mounted camshaft gear drive the 4BT parts do not fit.
Discussion Starter · #6 ·
Yeah the guy who put the B3.3 into the Jeep Wrangler was were I found out about that engine. That adapter would work but might be too long when stacked up with the SAE 4 flywheel housing.
I'd like to put a B3.3 into an S10 so I don't have as much space, althought I might be able to deal with the extra length.
From what I've found, the B3.3 is based off of a Komatsu design so there would be no 4BT part compatibility.
3.3L BT Cummins / Komatsu = SAE
No sweat, the older Nissan SD Diesels were SAE3 or 4....Wilcap Adapters has some bellhousings from the old days left in the back room, me personally I saved the SAE bellhousing from the diesel scout & intent to couple it to a 3.3L with a modified older bellhousing (hydraulic linkage) and an NV3550 out of a jeep......
1 - 7 of 7 Posts
