I have posted on this before and the “4BT hard knock” thread got me thinking. First let me describe. If my engine is at idle, the tensioner is moving 1/4”. To clarify, it is a 1/4” blur. On the other side where the belt goes from the crank to the first idler, I would say the belt bounce is about 1/2”. If I shift it in to gear, but don’t add throttle, that bounce is 3/4” or more. If I add some throttle, the bounce is gone at the free belt, but the tensioner is still a blur.
It drives fine, but I’ve always felt this is not right. In the “hard knock“ thread the OP mentioned “breaking the fuel lines to check injectors”. Could someone explain this? If one of my injectors was not firing, would that cause the belt bounce. Is it possible to have a bad injector and the truck drive this good?
If I “break“ the fuel line, how do you keep it from shooting fuel all over. Or do I not understand the term?
