1 - 7 of 7 Posts
Has anyone else had problems with belts shredding on their 4b/4bts?
The belt has not failed as yet and still looks "okay", but it is throwing off black dust and very, very small fragments. Inspecting the belt does not show clear damage (no torn off ribs, no nicks, no gouges). Currently I am at just under 100hrs on this installation. The belt is a NAPA 25-080550. Tension seems good. This is a factory marinized motor that I use for propulsion in my boat. Other than this it runs great. Has anyone else had experience with this condition?
One of you pulleys are mis-aligned, bent ect.
or you have a bad belt
Reactions: portsample
Had the same issue, alternator was out of alignment. Put a flat ruler and was 3/8" out. Shimmed it out and no noise or wear.
i had a belt tensioner get worn and out of alignment that was making the belt jump around and started taking inner and outer edges off the belt in the same way
If this is a "factory set up" and has worked for a long time and no problems, it's the belt tensioner.
Might make sure you don't have any rust or other roughness, etc. on the pulleys where the belt runs. That'll eat one in no time.
1 - 7 of 7 Posts
