1 - 7 of 7 Posts
Anyone know the bolt specs or who sells bolt kits for the ctd to motor plate and nv4500 bellhousing to motor plate?
Ausitn
There as close as your friendly Cummins dealer:smokin: Which one do you need? I have parts list for the Dodge and Chevy Trans adapters.
Steve
Whats the pN# for the dodge adapter?
Austin
I tried going to my Cummins dealer for power steering parts........despite a cpl and picture of the part, I came away with nothing. Thanks fo rthe help!
The Dodge trans adapter for the 89-93 is 3912184, 94-98+ is 3920381.
The power steering parts, vacuum pump, PS pump, you have get from Dodge or your local independent parts place. Even the adapter for the drive is from Dodge.
8 3920447 M12x1.75x40 bolts grade 10.9
Steve
Dodge adapters
hi, been following along here and not sure if numbers above were for bolts or adapters. We have an adapter here part # 3923045, supposed to come from 2nd gen 6bt. Another place we saw that the adapter is good for both automatic and manual application. Is this correct ?:confused::rolleyes::smokin:
Your adapter # is for the 94-2001 auto or manual.
Scott
1 - 7 of 7 Posts
