Bosch VE Diesel injection pump
By Robert Bosch
For many home mechanics the diesel injection pump is a bit of a mystery. The Bentley and Haynes repair manuals doesn't describe its internals, because it's not serviceable except by a few diesel specialists. Learning some basics of how it works and what its internals are could be of interest to the diesel owner, and the knowledge certainly can't hurt when troubleshooting fuel injection problems, even if one isn't about to take the pump apart.
The purpose of the fuel injection pump is to deliver an exact metered amount of fuel, under high pressure, at the right time to the injector. The injector, unlike in a gasoline engine, injects the fuel directly into the cylinder or a prechamber connected to the cylinder.
The VE in the name of the Bosch pump used in the VW diesels and many other small diesel engines stands for "Verteiler", which is German for distributor or divider. The other common kind of injection pump is the inline pump. The difference between them is that the "Verteiler" VE pump has one fuel metering plunger, and a mechanism (the "Verteiler"/distributor) to send the fuel to the right cylider. The inline pump has one plunger for each cylinder.
The Bosch VE has comparatively few moving parts, but what does move does so in a complex way. The figure to the left is from a Yanmar pump, which works and looks the same as the Bosch . On the leftmost end in the picture is the fuel feed pump. This is a vane pump, just like the vacuum pump on the VW diesel engine. Its purpose is to suck fuel from the tank and deliver it to the metering pump. All the things shown on the right in the figure have to do with the metering, timing and distribution of fuel delivery. The figure below shows this part in detail.
By Robert Bosch
