1 - 4 of 4 Posts
Hey guys, so recently I changed my govenor spring on my ve pump and snapped the threads on the throttle shaft off. I was wondering if anyone knew where to get a new throttle shaft. I ordered one for a 6bt ve pump thinking it would be the same but it was actually shorter so back to nothing again any help would be appreciated.
Discussion Starter #2
Or anyone with a ve pump could they give me there pump serial number, I’m having trouble finding mine
There should be an ID plate on the side of your VE pump that has the model and serial #. Probably the only place you can find that part is Bosch.
Any Bosch Diesel Service Dealer should be able to get you one. Call Oregon Fuel Injection at 541-485-1434. All they need is the pump part number which should be stamped into the pump housing. It's usually something like "0460424079".
1 - 4 of 4 Posts
