So when I was back home over Christmas I decided to try to adjust the valve clearance on the 4bt. Well looks like the timing pin is sheared off and while I can still reach it I'm thinking its a good idea to fix it. I've looked at the parts manual and it looks like you can get just the pin by itself. Looks like the PN is 3903924
Anyone try to replace just the pin? Is there an assembly available?
The other question is how do I set it to TDC to make sure the pin is aligned? Seems like I remember something about having to pull an injector and put some kind of stop in the injector hole.
