You can if you add a distributor, sparkplugs and a carburetor. If you want to keep it as a compression ignition engine you have to use Diesel as fuel.
Forgot, you'll need a new set of lower compression pistons too.
it doesn't worth the effort to make it run as an otto engine... diesel cycle is way more efficient, and also diesel fuel is easier to handle than gaseous fuels, and way safer than propane...
Okay, so I expected several folks to post in this section about their water/meth injection setups. Looks like a long wait. What, doesn't anybody run water/meth?
I did quite a bit of research on it and it sounded like an excellent idea, especially for towing. When you hit that engine-frying...
I've been reading a lot on adding CNG to your diesel. Fascinating stuff! There are some great threads out there including this one on CNGchat.com
http://www.cngchat.com/forum/showthread.php?t=26&page=1
Anyway, I've been trying to figure out what engine would be best for CNG, an electronic one...
Just found this on Ebay. kinda neat.
http://www.ebay.com/itm/Natural-gas-Cummins-power-units-for-irrigation-or-generator-sets-60-to-200-hspr-/130712528433?pt=BI_Generators&hash=item1e6f12e631
So I've read a few places online where having a liquid propane gas kit on a cummins 12 valve will help increase mileage by 2 or more mpg. I've also read on here that running LPG can give increase power output by a little bit. But I've heard that running LPG can decrease power output by about...
so here's what we got 1 woodgas producer, 1st generation will run a small briggs and stratton motor. next will be the 4bt that powers my stepvan. i have a turbo charged aftercooled 4bt that i want to run on clean filtered wood gas. i need to learn how to switch the fuel ratio on my bosch pump...
