I have not use the KW mounting kit yet,the frames channels are different on the 73-80's .My truck I just had to trim a bit and most of the A/C compressor fit'sinside the frame channel.CrewCab59 are you using the Kenworth a/c bracket/mounting location on those Cheby conversions? Drop in with some frame grinding IIRC, the Dodge a/c location was a potential issue on the 73-80ish conversions I have seen.
Can we get a front shot ??????my kw mount
This is the one I am talking about!Cummins makes an adapter to put the AC pump on the passenger side / upper mount.... Part # 3930888OE Alt Supt/Water Inlet $47. 60 old stock.
1100?????iirc it was 1100 for that MOUNT!
