Now that the steering column location has been completed I can start on modifying the Roxor clutch and brake pedals to fit. The 3 mounting tabs that normally mount to the dash needs to disappear and, the column clamp needs replaced since I've got a 2" column instead of a 1 3/4" like the older Jeeps and the Roxor has. Also I need to widen the assembly by an inch, centering the column in the dashboard mount.
Made a plate out of 7 gauge to mount the brake and clutch assembly to the dash. This dash has a steering column plate similar to the intermediate dash. The dash had nuts welded to the back of it the column mount bolted to those, ground them off for a flat surface. With this plate the column mount will bolt to the pedal mounting plate and sandwich the dash between. This will definitely stiffen the dash at the steering column.
