1 - 4 of 4 Posts
Can anyone recomemd a source for a clutch assembly and fork for my conversion. I imagine the OEM Doge stuff is super pricey and wanted to see if there were other options before heading that route.
Also, where is the best place to source a slave cylinder? Thanks.
dodge is actually the cheapest ive found and the least amount of guess work or headache. you dont have to buy the [artsw from dodge but the configuration. i picked up a bellhousing, clutch fork, 2 flywheels, starter, starter spacer and engine adapter plate for $200 .... now all i need is a clutch which i will be using the larger 13" 6spd disk with 1-1/4 hub and stock pressure plate along with a hydraulic assembly, dodge slave and probably ford master
I'm using stock dodge stuff as well, not the cheapest, but cheaper isn't always better :D It will last and hold up well, so the price should be worth it in the end.
I used LUK clutch assembly. They also sell the clutch slave.
1 - 4 of 4 Posts
