41 - 42 of 42 Posts
One plus is it does clear even though it is tight. Might need a small dimple in the firewall if more clearance is desired. If you're worried about heat transfer there you could have it ceramic coated. A bit expensive but that would make the heat almost nil.
Maybe cheaper (and quicker) to dimple the firewall and use some sort of heat barrier.
No question about that Russ. The high quality ceramic coatings aren't cheap. Another possible would be to make an adapter plate that would slide the turbo forward about 1 inch.
41 - 42 of 42 Posts
