1 - 3 of 3 Posts
I'm trying to plumb up the coolant hoses on my 6V53 and have come to the conclusion that I didn't take nearly enough pictures as I tore down the truck it came in.
I have the 3 main hoses to the radiator (1 bottom and 2 top) that much is straight forward. Where I have questions is there are some extra hoses that I'm not sure about. The fire truck the engine came out of had a water to coolant heat exchanger that I didn't need, so it was removed long ago.
(This is probably a question for NeoDan) Is this where that heat exchanger would have been hooked into the cooling system? Would the 2 spigots work for cab heater hoses?
129857
Next question: What does this hose do and is it necessary?
129858
3rd question: What does this hose do and is it necessary?
129859
129860
Any answers or discussion appreciated.
The outlet on the left.......base of thermostat housing...........is where pressure line for your heater core should go . The outlet on the right, just above the fan belt was initially designed for shutterstal or any coolant sensor . The hose is a de-aeriation line tp prevent air locks when filling the radiator and cooling system , The return line from heater core could be plumbed down there as well for the biggest temperature differential for good heater flow . De-aeriation line could be smaller .
1 - 3 of 3 Posts
