I installed mine first using a small piece of wood to start the sleeve then using the balancer pully on the front and the flywheel on the rear. My local cummins dealer dosen't have those tools. Also if you have a brass punch you could use that to get the sleeve on the last few millimeters. Rember it needs to be BRASS..Does anyone know of a resonable supplier of the installation tools, or an easy way of installing the wear sleeve seal assembly. The engine is completely disassembled.
