Hey guys, I have 4.5 years since my 12v conversion using a non intercooled '89 Cummins mated to a zf5 transmission. I used a flywheel off 94-98 Dodge truck (Sachs NFW7223 specifically) that I machined for a 6303-2rs bearing and used a stock clutch for a '89 F350 with a zf5 (Luk 07092). I can't find any specs but I believe it's a 12" clutch.
Anyway, I was doing something stupid and floored it while driving through some shallow flood water about 12" deep. After I got through I couldn't speed up. I couldn't use 3rd gear at all. I drove in 2nd gear low rpm and couldnt speed up or even make it up my hill in 1st gear. I had to use 4 low in order for it to not slip. I started it the next day and it still slips.
On my search for a clutch I saw that a (94.5-97) Powerstroke uses a 13" clutch. My flywheel looks to be drilled for 2 different sizes of pressure plates. My pressure plate uses the inner holes on the flywheel.
As best as I can tell South Bend uses the same flywheel that I'm using. But I have no idea if the bigger powerstroke pressure plate will bolt up to my flywheel. It looks like they use a Powerstroke clutch in their conversion kit. I was hoping to use a stock clutch and save some money.
Do you guys have any idea if it bolts up?
This is my Bronco but I used the same clutch/flywheel setup. You can see 2 sets of holes drilled. And my pressure plate bolted to inner holes.
