Okay, folks, I need some help. As some of you might recall, the exhaust side flange of my turbo housing seems to be worn a bit. And the clamp I had wouldn't fit tight --- the bolt part of the clamp just tore up --- threads stripped, etc.
So, I ordered a new clamp from atpturbo.com. I got a brand new:
CLC-CLA-012 V-Band Clamp - 2.50"
And it fit decent on the bench to my turbo exhaust side, shim, and exhaust pipe. Of course, I made several adjustments along the way, so I had to undo the bolt on the clamp about 3 times. Well, the threads are toast; stripped out.
So, is this a case of cheap steel bolt or am I doing something wrong? Has anyone else had a similar experience?
Thanks.
Thanks.
