my understanding of the marine engines was that the manifolds were water cooled but the turbo was still of a standard design, is that not the case?Beer Money, did you notice he said boat. This is a marine engine so turbo swapping isn't much of an option since those are water cooled. The VE pumped 150 HP. Not as powerful as the 250 HP P pumped model but more civilized and had less problems. Sunmar,It would be considered a good engine .but not sure what options you have as far as turning up the power. In theory it might be done but the turbo is going to be your limit. I believe the stock turbo was an H1C and it won't go much higher than the 150 HP level. There are no HX30W or HE221W that can be adapted. The 250 HP used an HX35 but it also had a P7100 injection pump feeding some 5x.012 injectors.
Many moons ago I had a friend who put a box truck 130hp 4BT into a 20' inboard. Rather than purchase the expensive but proper marine 4BT water cooled exhaust manifold and water cooled turbine housing, he sent both his out for a thick ceramic coating, along with the raw water cooled down-pipe. "White Lightning" ceramic coating if I remember correctly. He also ran a low speed bilge fan to move any engine compartment heat aft and out the console and gunwale vents. I only rode with him a few times after that but engine over-temp warning never tripped and the heat coming out the vents after 20 mins of steady cruise was not excessive by any measure. He had more trouble finding the right prop to reach cruising/planing speed under moderate boost while still allowing a nice slow trolling idle. Plenty of marine posts on here to soak up some good info/opinions.I am thinking of buying a boat with a cummins 4bt 3.9 150hp 1994. so I have some questions about the engine.
-what do I need to do to get it to 180-200hp and 350-450 torque?
- is it a good engine?
- is there a lot of vibration?
Yes, I know he did the usual tweeks to raise the power level ..injectors, 3200 lb gov spring, 60 lb valve springs, timing etc. Not sure he had it up to the 250hp marine rating, but it was certainly higher than 130hp when he finished. Failed to mention he also said he double wrapped (out of necessity) the entire stainless exhaust pipe from turbine to exhaust tip, in ceramic high heat exhaust wrap. With no heat exchanger cooling of the manifold/turbine to help off-load some of the exhaust heat, the exhaust downpipe ("riser/elbow" in boat lingo) was solely responsible for all the gas cooling via raw water injection into that pipe. Side benefit of the hotter manifold/turbine gas temps was quick spooling to get up on plane. He used a 45* turn-down tip at the stern - to avoid steam cleaning hapless swimmers on the rear platform.Viking, you can use the land engine in a boat like that but they generally don't have the power like a marine....
I have a boat with Twin 4BTAs at 250 hp. They are a good engine and will last a long time if taken care of (like any engine). They do vibrate but as soon as off idle they are smooth. I changed my 20 year old engine mounts and that reduced vibrations very much. I removed my factory raw water system two years back and installed a belt driven pump (off the crank) that has been excellent. Not sure what you can do to get more hp, you might try the forums at Seaboard Marine, sbmar.com I think.I am thinking of buying a boat with a cummins 4bt 3.9 150hp 1994. so I have some questions about the engine.
