1 - 17 of 17 Posts
has anyone done one? i know that they came in industrial equipment. i was thinking that this 3cyl might be handy where weight and length are an issue
I read somewhere about those, just haven't ever seen one. what did they use them in? that might be good for a small toyota 2wd truck or something.
They came in some of the case backhoes. I believe the 530 could be had with the 3 cyl B series engine.
My friend has a Case backhoe with the 3B engine, but I don't know what model Case.
Bob B.
For the size and weight per liter, I would rather run a Kubota or Isuzu 4 banger.
What would the weight difference be between them? Is it even worth it?? Not to mention the problems one would have finding a transmission to fit it. Also what is the RPM range of that engine.
Sounds like a cluster:rasta:
If it is a true "B" series engine it would share all front accessories and rear drive attachments with all other "B' series engines.
Industrial diesels at surplus center
These are industrial engines, and would be impractical for use in an automotive application. So would the 3B series engine, as it never came with an automotive style governor.
Bob B.
That is a good link. I've been looking into a small diesel engine for a generator to power an electric vehicle. Same principle as trains. For new engines, that is about par. I found a source of 4bt "crate" engines in Canada (bad part) for $7500 Canadian. What I mean by "crate" is a complete engine so all I have to do is put it in, hook the lines, and start it.
These are industrial engines, and would be impractical for use in an automotive application. ... never came with an automotive style governor.
I dunno about that - - most say: "Originally made for use in mobile equipment." To me that says they have speed governors on them, not load governors.
Dougal's Isuzu engine has a load governor - he would argue against you that it is impractical for road use.
what exactly is the justification for such a large jump in price??
I believe the metallurgy in diesel engines is superior to gas engines, and there are also a lot of other details (nearly all diesels have nitrided crankshafts, nearly no gas engines do) help to add up the cost.
Add another $2000 for a fuel injection pump and injectors!
I like that idea
Diesel engines are much mucH muCH mUCH MUCH more labor intensive to build than their gas counterparts. It reminds me of an old saying, "Big Trucks cost Big Bucks!"
1 - 17 of 17 Posts
