Ford 3/4 ton disc axles are all 69" WMS-WMS. Ford drum brake axles are 67.5" wms-wms . I don't recall there being a difference between the 1/2 ton and 3/4 ton disc axle widths.
The disc axles are wider because the open knuckles left 3/4" less room for the shock mounts on each side. The shocks wouldn't fit so Ford made the whole axle wider.
The 78-79 1/2 ton 44 front is the cheezball housing to stay away from with the integral wedges you mention. The earlier ones are all 3" 1/2" wall tubes.
The 78-79 3/4 ton HP 44 looks beefier than the previous 76-77.5 low pinion 44 front, but it's not. The tubes and housing are thinner.
