It's already been mentioned, but worth repeating: The R2.8 is entirely made in China, and has a very poor reputation for longevity. So, if you buy one you are putting money into a regime which literally puts people in concentration camps, and you are getting an engine that will have excessive blowby before a B series engine is even broken in. Thems the breaks.
There are other, better, non-Chinese light diesels out there. Personally, I would look into an ISB4.5. Yeah, I know, weight, blah blah. Everyone said the same thing when I replaced the 6.2 in my K5 (which itself had replaced a TBI 350) with a P-pumped 12V. Turns out they were only partially correct; the weight didn't negatively affect handling, but it was hard on 10b/D44 ball joints when combined with 37" tires. The stock frame also probably wouldn't have held up. However, that is a 6. If I had used a 4BT or ISB3.9 or 4.5, all of which weigh the same as the 6.2, I could have kept the stock axle and frame (had the frame not already been excessively cracked around the steering box area).
I know lots of guys are afraid of electronically injected engines, but the electronics are all pretty much self-contained to the engine, with the exception of the throttle pedal, so they are really an easy swap. Scariest thing is when the time comes to replace injectors, but it's the cost that scares you
Fortunately, they last a long time, and if you have a pump/injector shop just replace the nozzle components (or by remans) the price isn't too horrible. Other than that, they run nice, make decent power, and can make even more power if so desired. They are certainly quieter and shake less than a mechanically injected B series. Here's a 170HP ISB3.9 running:
