1 - 20 of 46 Posts
Hello all. I found these manuals in my carousing of the internet, and thought that I would make them available here. I have the following:
4BT Service Manual (85 MB)
4BT Operators Manual (17 MB)
4BT Parts Catalog (23 MB)
B Series Cylinder Head Capscrew Torque Manual (600 KB)
Bosh VE Pump Manual (1.6 MB)
I also have data sheets for ZF transmissions from Ford pickups, NP205 parts catalog, and even some PTO information. All these documents are in PDF format. The ZF transmission documents are small, but the rest are all to large to post here or to email. I would be more than happy to share any and all of this information to whomever needs it. Just let me know. I have printed off and bound my own copy of the Service Manual. It is very informative, and otherwise just really cool to have for someone that has one of these engines.
Zip the files
Could you zip the files and then send them?? If not, maybe break up the large files. Maybe the first 150 pages, so on.
I'm would like a copy.
Is there any information on which starter to use with the ford adaptor set-up. My starter currently has a broken tab and I need to replace it.
Fiddleback
Service Manual
Would greatly appreciate a copy of:
as well.
thanks
Dennis
Discussion Starter #11 (Edited)
OK! Just click on the link labeled with the manual you want, and click the download button. Thanks to BobS for suggesting 4shared.com. It was easy to use, and all yall get this stuff for free!!
4BT Manuals
Cummins 4BT Service Manual (85.7 MB)
Cummins 4BT Owners Manual (17 MB)
Cummins 4BT Parts Catalog (23.4 MB)
Cylinder Head Capscrew Torque Manual (722 KB)
4BT and 6BT Parts Catalog (520 KB)
4BT and 6BT Parts Catalog Prices (611 KB)
4BT Power Curves (133 KB)
4BTA Power Curves (137 KB)
4BT Dimensions 1 (700 KB)
4BT Dimensions 2 (919 KB)
4BT CPL767 Datasheet (76 KB)
4BT CPL767 Power Curves (79 KB)
4BT Starter Cross Reference (11 KB)
4BT to Ford SB Automatic Transmission Parts List (10 KB)
6BT Manuals
6BT Parts Manual (1.4 MB)
6BT Power Curves (134 KB)
VE Pump Manuals
Bosh VE Pumps Manual (1.6 MB)
ZF Transmission Manuals
ZF S5-42 Datasheet (69 KB)
ZF S5-42 Reman Specs (29 KB)
ZF S5-42 Transmission Years (29 KB)
ZF S5-42 Diagnosis and Testing Manual (758 KB)
ZF S5-47 Datasheet (85 KB)
ZF S5-47 Service Tips (844 KB)
ZF S5-47 Description and Operation Manual (800 KB)
ZF S6-650 Datasheet (162 KB)
ZF Application Progression Chart (13 KB)
ZF Cross Reference Chart (116 KB)
ZF Clutch Manual (66 KB)
E4OD to ZF 5 Speed Conversion Guide (24KB)
ZF Wiring Diagram 1 (29 KB)
ZF Wiring Diagram 2 (29 KB)
ZF Wiring Diagram 3 (27 KB)
Other Transmission Manuals
NV3550 Transmission Manual (1.4 MB)
Dodge Transmissions A500/42RH/A581/46RH/A681/47RH Manual (23.4 MB)
47RH Valve Body Installation Guide (1.4 MB)
Tubocharger Manuals
H1C Service Manual (3.9 MB)
WH1C Service Manual (4.8 MB)
HY30W Service Manual (4.8 MB)
HY35W Service Manual (5.5 MB)
HX30/32/35/38/40 Service Manual (5.7 MB)
HX50/55 Service Manual (4.3 MB)
HX50W/55W Service Manual (5.2 MB)
HE300W Series Service Manual (4.9 MB)
HE341VE Service Manual (1.1 MB)
HE351CW Service Manual (2.2 MB)
Other Various Manuals
NV4500 Exploded Diagram (156 KB)
NP205 Manual (337 KB)
PTO Application Information (37.5 MB)
Pac Brake Information (1.1 MB)
ARTSA Fuel Efficiency Lecture (1.8 MB)
I will post any more good information I find here. Happy Reading!!
Discussion Starter #15
I was just contacted by another user that wanted to add to the collection. I thought then that I would put it out to anyone who wants to contribute: If you have tech manuals, rebuild manuals, torque specs, or anything that you think might be beneficial to the group, send me a PM and we can work out a way for you to upload the files. I will take care of the organization and upload of the links. If we can compile enough, it might just be worth making this a stickey.
Am I the only one it doesn't work for?
When I click the link I get: "The file link that you requested is not valid. "
Discussion Starter #20
Sorry the links were down for a little while. I was adding some more file and needed to re-organize the others just for my sanity. I had to fix the links then. Everything should be functioning properly now.
1 - 20 of 46 Posts
