1 - 3 of 3 Posts
FORD complete adapter
Used Ford adapter set is in great condition. Includes; Cummins to Ford adapter plate, starter spacer, flywheel, hydraulic master/slave cylinder and lines, Ford manual bell housing, clutch, pressure plate, clutch pedal and bracket, and bearings. Will work with Cummins 4bt and 6bt up to 2002.5 On the Ford side it came with a T19 transmission but will work with t18, NP 435, ZF5, and will fit small Ford bell housings. The T19 goes with if wanted. $975 plus ride. E. WA. Will ship in two boxes. Email [email protected]
Sold
used ford adapter set is in great condition. Includes; cummins to ford adapter plate, starter spacer, flywheel, hydraulic master/slave cylinder and lines, ford manual bell housing, clutch, pressure plate, clutch pedal and bracket, and bearings. Will work with cummins 4bt and 6bt up to 2002.5 on the ford side it came with a t19 transmission but will work with t18, np 435, zf5, and will fit small ford bell housings. The t19 goes with if wanted. $975 plus ride. E. Wa. Will ship in two boxes. Email [email protected]
1 - 3 of 3 Posts
