1 - 20 of 43 Posts
I made an AC compressor bracket and i figured i would post it in its own thread. The AC has proved as hard as anything in the rest of my swap.
The mount is for a Sanden 7320 8 groove Compressor. Turns out Sanden's measurement of the mounting holes was incorrect, so be careful and measure everything yourself.
I had all the metal cut and holes drilled and tapped on the base plate at a shop in San Marcos, TX. Then made the alternator piggyback mount at home.
Then I ordered some hard ac compressor lines from nostalgic air parts and got some o-ring to flare adapters to use the factory Wagoneer #8 and #10 hoses. I replaced the evaporator, drier and expansion valve.
Getting it charged tomorrow. we will see what i screwed up then.
Banned
Nice..next summer will be cooler.
looks a lot like mine but my compressor sits upright--if the belt runs too close to upper hose just drill and tap the cummins bracket was just what mine needed. makin cold yet?
Absolutely love this AC setup the brackets look semi simple to build. How did you get your alternator down there. Mine sits way up top basically where your compressor is now. Do I need to have a totally different side setup or is there something im missing?
i dont know what setup you have, but I lied to you in my PM, the bottom bracket (really just a piece of flatstock about 2" long) was the factory one. I just had to clock it a little, then when you take the top bracket off it will just swing out into that spot. There is just as much clearance as before as the ALT just swung away from the engine a bit.
Discussion Starter · #7 ·
I just cleaned it, Try again
Banned
Thinder, did you end up running that thermostat housing or switch to a vertical?
Discussion Starter · #9 ·
same thermo housing. Belt Clearance was fine.
I'd like to see another picture of your belt set up..
.Mt 4BT is in a 72 Bronco and my alt. is up high also. I don't think I have room on top of the alt and under the hood. I'd like to see how the belt went around you alt and you compressor . Do you not have P.S.
I believe PS is on the back of the driver side. He clearly shows his top two mounts the only one in question is the bottom alt mount. I would love to see how to make it or a part number even if it is stock cummins.
Banned
The bottom alt. mount is on the water inlet. stock location. Thinder rotated it CCW and down, if he rotated it back up it would bolt right up to the stock alt. mount. Papitt you would have the room to do it, I do. Might lose some fender tho.
I mounted mine above IP and is v belt driven instead of serp. I wanted the option of not rolling it constantly.
View attachment 13208 View attachment 13209
redhedbronco, how do you tension the V-belt? That looks very close to what I have in mind, but it looks hard-mounted: no slack in the mount to allow the V-belt to be tightened up.
Discussion Starter · #14 ·
Thats all the pics I have. I sold the truck last Oct. But Redhead is right about how its the factory lower bracket, with the alt just rotated outboard. You probably have the room, it doesnt stick up past the valve covers.
Banned
Ryan, it is hard mounted, I had a tight belt on it, would get it about half way(lil more) over the top and roll motor over to flip it into sheave(sometimes). Was going to put a springed idler arm off the bottom(loose) side. This went to the back burner since I moved away from Vegas, dont even use AC anymore. Never took a pump apart and didnt know if I could rotate rear housing 90 degrees(bolt pattern looks like you can) I would have liked to use four bolts(instead of 2) like Thinders but would have put ports into IC piping on one side and rocker cover on the other. A hinged bracket wouldnt have worked for me either with the real estate issue(IC piping/rocker/hood) The tapered allen screws look sharp and might help on clearance issues. Anybody rotate the rear housing on an AC pump? Does gasket need to be replaced?
Thanks for the pictures of yours Redhedbronco .. I had gone out this evening an placed my compressor on both sides of my motor. Due to the fact that I have my air inlet tube bent around the front of my motor. I did not have any room for a compressor . My Alt in moved up to the center of pass side. So ther was no room on pass side either . I'll go back for a 2nd look over the injection pump tomorrow night
Banned
If your turbo/intake plenum tube runs around the front you probably dont have room on either side. You probably routed it that way for hood clearance but if you run tube back towards firewall over 4th rocker to intake it will clear your hood and free up room up front.
Discussion Starter · #18 ·
Papitt,
Im not terribly far from you. Im down in San Marcos. If you need a hand let me know. I have the Cad drawings of my mount and an extra 7320 Compressor laying around.
Thanks Thinder .. I've got a friend that has a CNC machine. I've got to check into seeing if I can route my intake around the back of the motor. I would Love to have AC.
Man I went to the shop and looked at mine this evening. I guess it can be routed around the back of the motor. But there is about 2 1/2 and the tubes are 2 inches. Also it looked like it'd be really close to the exhaust. Maybe 2 inches over the exhaust is that enough room.
1 - 20 of 43 Posts
