1 - 5 of 5 Posts
Rummaging through the last 12 years of archives for info on 353 & 453 injector details, I came across a few charts ..some which appear quite old.. that may help someone new to the boards in picking their injectors for their DD projects. These were mostly compiled and discussed previously by many knowledgable members, some whom are still here. These are by no means comprehensive in all the possible injector part numbers offered by DDC, but a good start on the ones most 353 & 453 "builders" would primarily be interested in. If anyone has any charts with newer and/or more complete details, cut & past here :)
Font Parallel Rectangle Symmetry Paper product
Font Rectangle Parallel Paper product Paper
Rectangle Font Parallel Paper product Paper
Font Rectangle Parallel Paper Paper product
Font Parallel Pattern Rectangle Monochrome
Font Parallel Pattern Number Paper
Font Material property Parallel Number Pattern
Great !! thanks for the contribution. Ill have access to a late 80's to early 90's (publication date) DDC "Field Service Data Book" soon. It should show if there were any newer/updated injectors available after the "Silver" versions of the 353T, 453T engines were released in mid-1984. Prior to that only the "green" version of these 353T & 453T engines were available.
Here are the Detroit Diesel injector summary charts from a 1991 "Field Service Data Book". Lots or repeats but I see some new ones as well. A bit disappointing they stopped listing the # of holes in the tips and their diameters, as part of this data by 1991. Maybe those details are listed in a different DDC publication. I guess you can back into the tip info by cross referencing the tip part number. At least the fueling range (calibration) is listed for each injector.. These charts should capture any new or updated injector information for the "Silver" 53 series engines released in 1984.. Other engine series are shown as well.
Font Number Paper Pattern Symmetry
Font Paper Number Paper product Document
Font Paper Document Paper product Number
Font Paper Event Pattern Paper product
Font Paper Pattern Paper product Document
Font Paper product Document Paper Number
Font Paper Document Paper product Event
Font Rectangle Number Paper Paper product
1 - 5 of 5 Posts
