401 - 420 of 463 Posts
Discussion Starter #401
Another good weekend, I finished building and loading the pistons in the liners. Installed the cam, counter shaft, oil pump, end plate, timing gears, oil pump drive gear and front cover.:) Finally starting to look like an engine again, next weekend is loading the liners.
Cross Head piston assembly:
127919
127920
127921
127922
Nice progress. When you get it done you'll have a basically brand new engine. Gaining plenty of knowledge at the same time.
Discussion Starter #403
Found an old 6.4 video, so I uploaded a cabin noise comparison for fun.:) Detroit was 60.5 at idle and around 75-78 at 2000 rpm.
Discussion Starter #405
Happy times, got the head assembled and torqued down. Injectors, lines and rack are in as well. I found a bent rack control arm that I missed before. I've straightened it now and just testing it to make sure it's free. Not far off getting it finished up.:)
128050
128051
128049
Looks so much more complicated as compared to a B Cummins. Can't wait to see a first start vid!
Sent from my SM-G970U using Tapatalk
Discussion Starter #407
True, it's really not anymore complicated, just different.:) I'm dying to hear it run as well.
Discussion Starter #408
Had a good weekend on the Detroit. Installed the rear housing, front, rear crank seals and sleeves, shimmed the governor down from 3200 to 3000 rpm. Flushed the oil cooler, oil pick up tube, washed and installed the oil pan. Next weekend it's the blower, oil cooler, Jake heads, tune up and engine start.:)
128161
128163
128162
128164
128165
128166
128167
128168
Discussion Starter #409
It's alive.:) Finally got it tuned up and quick test run up to check for leaks. Very happy with the results, super responsive now that I have the new cam and pistons in it. As well, I worked on the governor and fixed a few issues I noticed. Very happy indeed.:)
Discussion Starter #411
Another fun weekend on my 4-53T. Changed the out my K27 bypass actuator for another unit that now opens at 15 psi instead of 30. This will hopefully lower egt's and help light the k31. Mounted up the turbo's and made a new fuel shutoff system using a second gen solenoid. Just a couple of items left and the engine goes back in the frame.:)
128352
128353
128354
128355
Discussion Starter #412
Happy times, she's back in the chassis.:) Repaired a high spot on the cross member and then put the engine back in. I'll soon be converting diesel fuel into noise.:)
128369
128370
128371
128372
128373
Discussion Starter #415
Got the truck turned around and most of the hardware re-attached. Did a quick start to test for leaks and no leaks found.:) Started working on putting the Turbo breather back on the valve cover. The N style I made had no baffles so a lot of oil would puke out the breather. It shouldn't puke anymore now that it's a new engine, but better safe than sorry.:) I should have the cover finished and get the rig rolling by the weekend.:)
Start and leak check.:)
128418
128419
128420
128421
128422
Bringing back up your AN fittings on your AC system. Do they seem to be working out ok? Are you running any ORB fittings in your system? Making some parts up for my expedition ac system and just making sure you are having good luck. I had to make a custom line adapter that bolts to the compressor so I could get the lines pointed in the right direction and I cut ORB fittings for the lines to adapt to, from there ill go to AN stuff.
Discussion Starter #420
I haven't charged the AC yet, but did vacuum test it and it passed. I waiting until I get all the tuning right before I charge the AC.:)
