1 - 6 of 6 Posts
Hello Fellow Deutz Fans And Diesel Mechanics,
I need assistance with the cold weather starting of a newly acquired D6206. Can someone tell me where the yellow wire coming from the fuel solenoid connects? mine was not connected at time of purchase. All help will be greatly appreciated. Thanks
A picture of the setup would also help 😉
I have the manual it's not easy to read . Looking for someone to respond that is familiar to the Deutz manifold heater setup. Thanks
The pictures you have provided from the manual helps a lot, thanks
I take it is an air cool diesel ... depending on the degree of cold.. they make things like magnetic oil pan and block heaters.. or give it a short burst of ether... or you cover it with a tarp and put a sunflower heater under the tarp.. unless it is like all the Deutz tractors I worked on and leak oil like a hog.. them you have to be careful with using a propane heater..
1 - 6 of 6 Posts
