What is the difference between No. 1-D diesel fuel and No. 2-D diesel fuel and can they be used interchangeably?
Always check with the manufacturer about the fuel requirements of your engine. However, both No. 1-D and No. 2-D are intended for use in compression ignition engines. In fact, in cold weather, No. 1-D is blended into No. 2-D or used by itself.
Three of the biggest differences between the two fuels are cetane number, heat content, and viscosity. The cetane number of No. 1-D may be one to two numbers below that of No. 2-D, but still above 40, the required minimum.
Since No. 1-D is less dense then No. 2-D, its heat content, measured in Btu/gallon, will be a few percent lower, leading to a similar reduction in fuel economy.
