1 - 2 of 2 Posts
You need to look for a different tag. RSV 475 is the tag for the pump governor. Usually mounted on the end of the pump. The pump ID tag is normally on the side of the injection pump. Model number will usually start with PES and then more numbers and alphas depending on pump type. Do you have a photo of the side of the pump? I assume it is an inline type but could be an A, P3000, or P7100.
1 - 2 of 2 Posts
