1972 F250 4x4, 78 d60, 3.55, np205, 200hp 4bt nv4500 in progress
Sorry for a common knowledge question.
Moving battery and solenoid over to DR side, will make up a 7' 4ga charging cable from dodge alternator. Parts stores carry 14 ga fusible links which seem chinsy attached to a 4ga cable. If a 'maxi fuse' is used, should I use a 120Amp fuse to match the alternator output?
Thank you..
Sam
Thank you..
Sam
