Well, not any different than you do I would guess hah! Problem is many folks are used to a torqueless wonder of a gasser: REV motor, SLIP clutch and get under motion quickly to escape the burning disc smoke.
With a diesel the proper way is to simply ease out the clutch and IF NECESSARY give it a touch of fuel, then when fully released step on the go pedal. The bottom end off-idle torque is plenty to get ya rolling without clutch slip. If it isn't then turn the idle up a smidgeon.
Roll all stops signs, slowing to a crawl way before the line and keep rolling momentum up. While still rolling let the clutch out and drive through normally.
When I do that at stop signs I come up a little fast and so make a visible slowdown ALMOST to stop, and then take extra time rolling up to the line very slowly, much more time than a car that quickly stops and takes off. Had cops watch me do this many times, no complaints yet, because I'm looking in all directions and driving very safely. They usually understand about diesels for the most part.
On all upshifts and downshifts match engine rpm to mainshaft speed. That is, double-clutch on all downshifts also.
Whenever coming to a full stop, if possible, pop it in neutral instead of sitting there with the clutch linkage riding the throw-out bearing.
Doing these things will make a 6BT clutch behind a 4BT last for MANY miles with no complaints.
