Gentlemen,
I'm thinking about mounting an A/C compressor on the drivers side, next to the first valve cover. It would be powered by it's own v-belt from the fan drive pulley. I have the pulley that mounts to the fan drive, and I have space on the drivers side to mount a bracket for the compressor. From what I have read, other vehicles have used this location to power a vacuum pump. This is in an 87 Jeep Grand Wagoneer that I use as a daily driver. I still have some of the original hoses, and heat exchanger, but I tore out most of the stuff when I put in the 4bt, including the controller. The A/C system did not function.
So my questions...(keep in mind I have never worked with A/C at all
1) Will that belt have enough traction to power an A/C compressor? 2) How do I go about choosing what compressor I need? Looks like Sanden is the go-to, but how do I go about choosing a specific model? 3) To what extent are A/C parts compatible? How do I go about getting a system (on somewhat of a budget) that can work together? Should I go to a junkyard and gut everything from one vehicle, or are the systems pretty interchangable? 4) Anybody have a PN or anything for a bracket I can use to mount the A/C
I really appreciate any thoughts you guys have on this. I'm pretty ignorant on the subject! :rasta:
