I am about to embark on a major overhaul/hx30/35 compounds on my truck, and due to clearance issues I need a remote oil filter setup. I recently purchased a dual remote oil filter head and thread-on block adapter which I plan to use two stock filters on. The ports on the filter head assembly are 1/2" npt and so are the ports in the block adapter. The kit comes with hose barb fittings that I'd rather not use and instead use an hydraulic hose with JIC fittings. My question is weather or not -8 an fittings will flow enough oil and not cause a restriction to vital engine components. My understanding is that 8an is 1/2" I'd, is that correct? Thanks. This is on a 4bt.
Link to eBay http://m.ebay.com/itm/221219393608?nav=SEARCH
