I am using the HX35W turbo on the high mount exhaust manaflod, I had 1/2" clearance on my 86 F-350,with the 300 stands and org. mounts. The exhaust outlet of the turbo was very close to the firewall when I had it on the 300stands, There would not have been enough room for the down pipe. I used 1st gen Dodge mounts, 1/4" higher then the stock bread van mounts the engine ended up sittin 4" from the crossmember, Personal preference I fabed my own mounts and set the engine as low as I could get it into the frame, plenty of clearance now, even with the HX35W.
This pic shows the engine on the 300 stands and the ZF trans crossmember see all the area between the pan and the front crossmember.
This pic shows where the engine ended up after fabing mounts. I do not know much about the two wheel drive trucks, I just figured if your going to go thru with the swap it would be a 4X4. I personaly do not like the Mazda trans found in the 1/2 tons, thus the 3/4 ton pick as well as the 300 inline in the donor truck so that there will be very few changes to the truck. I think the 3/4 ton front ends will hold up to the wieght better anyway.
I found a 1988 F-250 light duty with the 300 six inline and the ZF 5 speed 4x4, I used the trans transfer tranny crossmember and the front drive shaft from this truck. It would of been a perfect starter truck for a conversion, pull the 300 out install the 4BT and away you go!
