So just a quick update... I almost have 6000 miles on the transmission now and I finally found a load to pull. Gross weight was right around 27k. It was really slick to have the low first gear and even lower reverse. Forklift weighs in around 13k by itself.
Forklift engine needs a little work - it has a sheared distributor/oil pump shaft pin. So the engine needs to come out and the oil pan needs to come off to pull the oil pump assembly. But, hey for $375 I can't complain. I also finally got the thermocouples in place in the up-pipes. No pictures of the thermocouples yet.
[/QUOTE
Is the lift a Toyota ? Is motor a strait 6 ? If yes the motor is actually a Chevy metricized in Japan, the motor of the early land cruiser, I have one, you can improve the starter by putting a Chevy on it , just elongate the bolt holes a little
