1 - 14 of 14 Posts
· Registered
I had a line on a set of P30 eng mounts but they were sold out from under me...... So what is the best mounts to put in there and where can I find a pair? The mounts that I have now are about 1" thick rubber and if this little diesel is gonna shake like you guys say, I think an upgrade is in order before I fab the engine mounts for my Scout. -Wingnut
· Registered
Alright I'm dragging this one up again because I still need mounts... and I see I'm not the only one if you take a look at the classifieds. What mounts are people running and how do you like them? I need to set my engine in the frame soon and I have nothing to mount it with! -wingnut
· Registered
If you cant find anything else easy, order a set for a 91 dodge truck, 6bt from your local advance auto. Not as nice as fluid mounts, but they will work fine, and are easy to come by. Just fab your own brackets if you dont have any.
· Premium Member
Can you post a pic of these Benz mounts? Thanks...
· Registered
Bob,
How about the part # for those Ford mounts. The application would be nice also. Are yours factory Ford or aftermarket?
CT-CUMMINS-BLAZER,
I tried the auto local parts store. They don't have the SD300 mounts. They have #s but not available. Who has them?
· Registered
Are these the Ford ones? I maybe assume so saying everything else on the Winnebago was...
Also just a thought, maybe not a great one but still a thought; Has anybody used a gas shock to help dampen engine movement. It just crossed my mind and is used on higher performance front wheel drive cars to prevent engine lash, maybe something like a truck shock could take away some of the idle vibration...
1 - 14 of 14 Posts
