Working on getting my engine set. I had a small block chevy perviously mounted to the same trans i'm using. I used the old trans cros member to relocate the trans and that worked pretty well. The issue I'm having is the passenger motor mount is really low with the 10* tilted adapter. I'm using the fluid filled mounts and made custom engine side mounts. Copied the one used to mount AC in the "show ur motor mounts thread. The motor is pretty good front to back and side to side. Its just the height of the passenger side mount. The half of the mount going to be welded to the frame is going to sit like 5 or 6 inches below the frame. A picture would be worth a thousand words but I'm at work without my camera. Any suggestions. What is everyone else doing to set a good engine height or does anyone have pics?
Thanks in advance
Chris
Thanks in advance
Chris
