I pulled up to my parking space, and right as I was reaching for the key to shut it off, the damn thing just quit as if I had already turned the key off. I put 12 volts to the fuel solenoid and I can hear a nice click, it sounds normal.
I opened the drain on the bottom of the spin-on fuel filter, pumped the fuel pump lever, and no water came out, just clean fuel. I closed the drain, and primed the fuel pump lever but the lift pump works fine and moves fuel. Now what the hell do I check? Everything seems fine.
Can the fuel solenoid go bad and still click normal-like? I had great power on the drive there. What all can go wrong/what is the next thing to check?
