I'm very interested in the mount part of this as I'm just at that stage on my RAM 1500 swap. On my Dakota swap I used marine mounts and they were not bad but this year changed to the Anchor fluid mounts and it made a nice difference.
Dougal are you talking about having a custom rubber mount built or the steal parts? Its hard to imagine a set of the steel mounts that could be universal. I have done 6+ swaps and could not have used the same mount design on any two. I tried to sell welded mounts for the VW TDI swaps but they never worked for more than one application and even then some guys wanted to mount the engine at a slightly different angle or location. In the end I offered them as an unwelded kit and that worked very well. I think most guys that can do a swap have the ability to fab mounts. All my swaps are mid mounted, most of the vehicles I have done just don't have any structure ahead of the axle that's strong enough to mount to. As far as the vacuum pump for brakes, I have used the Isuzu NPR alternator on a couple of swaps. It has a good vacuum pump built onto the back of the alternator and has lasted for years with no problems. On my current swap I'm going to use the Ford belt driven pump because I have room. Here is the TDI frame mount kits I sold. and then the engine side mounts.
