This pump?
That pump is an Eaton Vickers V10-NF. It is an SAE A mount pump with an 11 spline male input shaft. There are many different pumps available that all mount to an SAE A two-bolt flange and have 11 spline inputs. Note that 9 spline shafts are also available, but 11 spline seems to be more common for PS use. The "NF" in the basic part type indicates that it has an internal pressure regulator valve. Regular V10's for general hydraulic applications can have a pressure control valve or a flow control valve, or no valve at all. The pressure and flow control versions have a separate output for the fluid that the valve bypasses, whereas the NF returns the excess fluid to the pump inlet internally. The pumps without any pressure or flow valves must use an external regulator. The NF pumps are intended specifically for PS use. The pump on my engine puts out something like 6GPM and 2800psi max.
Here's an example of a TRW pump for a Freightshaker application. Its rated for 4.23gpm and 2683psi:
The component that allows the use of an SAE A mount pump is a gear drive SAE A PTO adapter like this one:
If you look around you may be able to find that SAE A adapter on the used market. Im not sure how long the bearings last. Mine came with the engine, and I have no idea how many miles/hours are on it. There is an oil hole between the gear and mounting shoulder that allows splash/drip oil into the bearings for lubrication, so it doesn't rely on grease for lubrication.
The Vickers V10-NF is a very tough, durable, all-cast-iron pump. Its also probably the most expensive. The disposable aluminum pumps like that TRW unit and many others are probably Chinese, which would account for their lower price. Once again, if you can find a used Vickers thats in good shape, it should give very long life. They are easy to re-seal if they leak, and they are completely rebuildable. Theres only a few wear items in the pump, all of which are replaceable. Again, I have no idea of the history on mine, but it makes no noise and works VERY well! I run a spin-on hydraulic filter in the low pressure return circuit (highly recommended) and use only high quality, high vicosity index, anti-wear hydraulic fluids.
