I have a 4bt that is missing the ID tag. (the one on the gear case)
Where is the s/n stamped on these blocks?
I called Cummins tech support and they told me that none of the B series engines have the s/n stamped in the block. I find this very hard to believe since the gear case is not part of the block and can be removed. Cummins said to try to back track the vin #. The truck my engine came from was re-powered from a gasser to a diesel so the vin will show a gas engine. Secondly the division that did the re-power work is now defunct.
My B series manual does not say anything except for the ID tag.
